PostGIS Raster Writer Parameters
Database Connections |
Connections store authentication information. For general information about sharing database connections, please see Using Database Connections. Note that different subsets of Database Connection parameters are made available in different contexts. ![]() Select an existing connection, or Add Database Connection to define a new connection. The new connection can be made visible only to the current user, or can be shared among multiple users. |
Connection Parameters
Note: The source and destination dataset must be set to the database name.
This specifies the machine running the PostGIS/PostgreSQL ORDBMS as either an IP address or host name. The database must have proper permissions and be set up to accept TCP/IP connections if connecting from a remote machine.
When connecting remotely, this specifies the TCP/IP port on which to connect to the ORDBMS service. The default port is 5432.
This specifies the name of the PostGIS-enabled PostgreSQL database. The database must exist in the ORDBMS.
Enter the username and password to access the database, user account, or wherever authentication is required.
Table Creation
Specifies the name of the column to be created that will hold the raster data when creating a new PostGIS table.
If set to Yes, changes the case of attribute names to lowercase.
