Google Cloud SQL Non-Spatial Writer Parameters
Database Connections |
Connections store authentication information. For general information about sharing database connections, please see Using Database Connections. Note that different subsets of Database Connection parameters are made available in different contexts. Connection
Select an existing connection, or Add Database Connection to define a new connection. The new connection can be made visible only to the current user, or can be shared among multiple users. |
Connection Parameters
This specifies the machine running the MySQL DBMS as either an IP address or host name. The database must have proper permissions and be set up to accept TCP/IP connections if connecting from a remote machine.
Contains the TCP/IP port on used to connect to the host running the MySQL database. The default port is 3306.
When you enter the file name of the Database in the Destination Dataset field, the Database field will be automatically populated in the Parameters box.
Enter the username and password to access the database, user account, or wherever authentication is required.
