MariaDB Non-spatial (MYSQL_DB) Writer: User Attributes
For information on the parameters in this dialog that are specific to all formats, see About Writer Feature Types: User Attributes
User attributes for this format are defined below.
| Name |
The name of the field to be written. Valid values for field name include any character string devoid of SQL-offensive characters and less than 63 characters in length. |
| Type |
The type of a column in a table. The valid values for the field type are listed below: bigint blob char(width) date datetime decimal(width, precision) double(width, precision) float(width, precision) int longblob longtext mediumblob mediumint mediumtext smallint text time timestamp tinyblob tinyint tinytext varchar(width) year |
| Index |
The type of index to create for the column. The valid values for the index type are listed below: BTREE (default attribute index) HASH PRIKEY (primary key) |
