Text Strings
igds_type: igds_text
Text string features correspond to IGDS element type 17. Normally, text strings are grouped together into a single complex element within MicroStation by text nodes. However, such text groups are handled in FME by the igds_multi_text type and not by this type, which is used only for single, free standing text strings. Text string features are point features, and only have a single coordinate.
Note that V8 reader is capable of reading texts in Unicode (UTF-16) in Windows only.
Tip: Some applications may use the graphic group field to logically group related text elements together.
Text strings have the following attributes:
Attribute Name
Notes
Contents
igds_original_justification
This attribute contains the original justification of the element when it was placed in the Design file. Once placed, all text elements are stored in the Design file using lower left corner (code 2) justification. Therefore, all text elements returned by the reader have an igds_justification of 2.
The IDGS reader returns the original justification code in this attribute. The IGDS writer stores the value of this attribute in the justification bits of the placed text element, but it does NOT use its contents to determine placement of the text.
Range: 0..12
igds_text_string
Reader only
The text string to be output. Text strings longer than 255 characters cannot be stored in a Design file and will be broken into multiple separate text elements.
Range: Any string
Default: No Default
igds_font
Reader only
The IGDS font number for the text string. Values from 0..511 are RSC fonts, while values from 512..1023 are SHX font, and values above 1023 are True Type fonts.
Range: 0
Default: 25
igds_rotation
Reader only
The rotation of the text string. The rotation is measured in degrees counterclockwise up from horizontal.
Range: -360.0..360.0
Default: 0
Reprojectable: Yes
igds_justification
The justification code for the text string. See the Text Nodes section for documentation on the mapping of numbers to alignments.
Note that if this is specified, the IGDS writer will compute the lower left corner of the text as best it can and use that when the element is written to the Design file. Text elements in a Design file are always stored using a lower left corner.
The igds_original_justification may still be used in addition to this value, to override the justification bits of the placed text element.
Range: 0..2,6..8, and 12..14
Default: 2
igds_text_size
The text size of the text, measured in ground units. This is stored as the height of the text element.
Range: Any real number > 0
Default: 20
Reprojectable: Yes
igds_text_width_multiplier
The text width of the text. The text width is measured in ground units.
If this is not supplied, then igds_text_size is used.
Default: value of igds_text_size
Reprojectable: Yes
igds_text_num_lines
If this is specified and is greater than 1, it will cause the text string to be broken into the number of lines specified, and output as that number of text elements stacked vertically.
Range: Any integer > 0
Default: 1
igds_text_horizontal_flip
Indicates whether or not the text should be flipped horizontally when it is displayed. This is represented in a Design file by storing the text width as a negative number if the text should be flipped.
(Not included in Version 8 DGN files.)
Range: Yes|No
Default: No
igds_text_vertical_flip
Indicates whether or not the text should be flipped vertically when it is displayed. This is represented in a Design file by storing the text height as a negative number if the text should be flipped.
Range: Yes|No
Default: No
igds_insertion_x
igds_insertion_y
igds_insertion_z
Reader only
The x, y, and z location of the original insertion point for the text, before the justification was applied.
Reprojectable: Yes
igds_lower_x
igds_lower_y
igds_upper_x
igds_upper_y
Reader only
The lower left and upper right x and y coordinates of the bounding box of the text. For text members of split text node elements, these bounds represent only those of the text member, while the more generic igds_xlow etc. attributes represent the bounds of the overall text node element.
igds_textstyle_id
The ID of the textstyle being used.
When writing, this ID may associate an existing text style definition in the seed file with this text element. If a matching ID is found, then that text style information is applied to this text element as the default style. Any text style specification for this text element on the feature as igds_textstyle_* attributes will take precedence over the matched default text style information.
Default: None
igds_textstyle_bold
A flag indicating that the text should have a bold style. This takes precedence over the bold flag integrated into the igds_textstyle_exflags attribute.
Default: None
igds_textstyle_char_spacing
Textstyle character spacing between characters. When writing, this is not used if an existing text style is found that has either inter-character spacing, fixed-width spacing, or AutoCAD-related spacing flags already set.
Default: None
igds_textstyle_slant
This is the angle in degrees that the text slants, clockwise for horizontal, left-to-right text, as specified by the text style. This is a property which is part of the specification of italics.
An angle of 30 degrees is usually used to apply an italic style.
This takes precedence over the slanted flag integrated into the igds_textstyle_txflags attribute.
Range: -180.0..180.0
Default: None
igds_textstyle_underline
A flag indicating that the text should have an underline style.
This takes precedence over the underlined flag integrated into the igds_textstyle_txflags attribute.
Default: None
igds_textstyle_underline_spacing
Textstyle underline spacing
Default: None
igds_textstyle_underline_color
Textstyle underline color
Default: None
igds_textstyle_underline_style
Textstyle underline style
Default: None
igds_textstyle_underline_weight
Textstyle underline weight
Default: None
igds_textstyle_overline
A flag indicating that the text should have an overline style. This takes precedence over the overlined flag integrated into the igds_textstyle_exflags attribute.
Default: None
igds_textstyle_overline_spacing
Textstyle overline spacing
Default: None
igds_textstyle_overline_color
Textstyle overline color
Default: None
igds_textstyle_overline_style
Textstyle overline style
Default: None
igds_textstyle_overline_weight
Textstyle overline weight
Default: None
igds_textstyle_line_offset.x
igds_textstyle_line_offset.y
Coordinates of textstyle line offset
Default: None
igds_textstyle_codepage
Textstyle codepage. Specified as the integer portion of a Microsoft Windows code page, i.e., 1252 for Latin I.
Default: None
igds_textstyle_bg_color
Textstyle background color
Default: None
igds_textstyle_bg_style
Textstyle background style
Default: None
igds_textstyle_bg_weight
Textstyle background weight
Default: None
igds_textstyle_bg_border.x
igds_textstyle_bg_border.y
Coordinates of textstyle background border
Default: None
igds_textstyle_bg_fill_color
Textstyle background fill color
Default: None
igds_textstyle_color
Textstyle color
Default: None
igds_textstyle_font
Textstyle font
Default: None
igds_textstyle_tnode_word_
wrap_len
Textstyle word wrap length
Default: None
igds_textstyle_overrides_style1
igds_textstyle_overrides_style2
Textstyle override style flag
Default: None
Textstyle flags. A reasonable setting to enable text style on write is 512.
The bits of this integer value indicate the different text style properties to be applied to this text element. In general, these properties are specified by the other igds_textstyle_* attributes. If those attributes are set when writing a text element, the associated bits of this flag will automatically be set. For interpretation when reading, the following values are the base values for flags, which are added together to create the integer value of this attribute.
  • inter-character spacing = 1
  • fixed-width spacing = 2
  • underlined = 4
  • slanted = 8
  • vertical= 16
  • right to left = 32
  • reversed multi-line = 64
  • kerning = 128
  • offset = 256
  • codepage = 512
  • shx big font = 1024
  • background color = 2048
  • subscript = 4096
  • superscript = 8192
  • extended text = 16384
  • text style = 32768
Range: Valid unsigned 16-bit integer
Default: None
Textstyle extended flags are like igds_textstyle_txflags, but apply to extended textstyle properties.
This attribute will be set from text styles during reading, and will be used to create text styles when writing. The bits of this integer value indicate the different text style properties to be applied to this text element. A limited number of these properties are specified by the other igds_textstyle_* attributes. If those attributes are set when writing a text element, the associated bits of this flag will automatically be set. For interpretation when reading, the following are some of the base values for flags, which are added together with other bits to create the integer value of this attribute.
  • overlined = 1
  • bold = 65536
  • underline style = 131072
  • overline style = 262144
  • style overrides = 524288
  • word wrap text node = 1048576
  • color = 4194304
Range: Valid unsigned 32-bit integer
Default: None
Note: When a text string feature is reprojected, its rotation and text size are also automatically adjusted to be correct in the new coordinate system.
Note: When writing textstyles, make sure that all the textstyles are added to the seed file being used.
