GTViewer Elements
The GTViewer format contains a variety of element types. The GTViewer format is designed to provide elements with different coordinate precisions to better utilize resources on platforms that are limited. While the format does support 16, 32, and 64 bit elements, only the 32 bit elements along with two 64 bit elements (arcs and ellipses) are supported by the Reader and Writer modules.
The GTViewer format also provides two different approaches for defining styles for the element display: Instance Based and Filter Based. Instance Based Symbology encodes specific style information on the element itself (color, weight, linestyle, etc.). Filter Based Symbology uses the Filter Id on the element to determine which Dynamic Style Rule to use when displaying the element. When using Filter Based Symbology, all elements with a particular Filter Id (in a given category) will have the same style (color, weight, symbol, font, etc.). The Filter Id is also used to determine which elements are displayed.
The following table lists all of the GTViewer Data Element types and type names used by the Reader and Writer modules:
gti_TypeID
gti_type
Description
3
gti_group
Aggregate, Composite Line, Composite Shape, Composite Shape with Holes.
6
gti_data
Data only element, no geometry.
100
gti_point32
Single point element.
101
gti_line32
Line consisting of 2 points.
102
gti_lineString32
Line consisting of 2 or more points.
103
gti_shape32
Closed Shape consisting of 3 or more points.
104
gti_arc32
Elliptical Arc defined by a primary axis, secondary axis, start angle, sweep angle, and rotation.
105
gti_circle32
Circle defined by an origin and radius.
106
gti_ellipse32
Ellipse defined by a primary axis, secondary axis, and rotation.
107
gti_text32
Text defined by string, origin, size, rotation, and justification.
109
gti_symbol32
Oriented Point.
110
gti_3pointArc32
Circular Arc defined by an origin, start point and end point.
112
gti_dimension32
Two point line containing a dimension label.
114
gti_shapeWithHoles32
Closed shape with one or more holes.
204
gti_arc64
High precision elliptical Arc defined by a primary axis, secondary axis, start angle, sweep angle, and rotation.
206
git_ellipse64
High precision ellipse defined by a primary axis, secondary axis and rotation.
The following table describes all of the properties common to all GTViewer elements and are used by both the Reader and Writer modules:
Property
FME Property Name
Description
Value Range
Element Type Id
gti_typeId
Identifies the Type of Element
3 – group
6 – data only
100 – point 32
101 – line 32
102 – line string 32
103 – shape 32
104 – arc 32
105 – circle 32
106 – ellipse 32
107 – text 32
109 – symbol 32
110 – 3 point arc
112 – dimension/leader line
114 – shape with holes
204 – arc 64
206 – ellipse 64
Filter Id
gti_filterId
Identifies the Filter Class an element belongs to. Filter Classes are used to determine which elements are displayed and how dynamic style rules are assigned.
0 to 2499
Color Id
gti_colorId
The color ID of a color in the color table to use for the element.
0 to 255
Linestyle Style Id
gti_styleId
The ID of a standard linestyle pattern to use for the element.
0 to 7
Weight
gti_weight
The weight of the element
0 to 15
Fill Flag
gti_fill
Determines if fillable elements (shape, ellipse, circle, composite shape, shape with holes) are filled or hollow.
0 or 1
Extended Style
gti_extendedStyle
Defines an extended style for linear element, text, and group elements. Linear elements use the extended style ID as a user-defined linestyle ID. Text uses it as an extended text style (underline, strikethrough, box, rounded box). Group elements use it to identify the sub-elements as an aggregate, composite line, shape, or shape with holes.
Linear Elements:
UDLS id: 0 to 999
Text Elements:
0 – Regular Text
1 – Circle Box
2 – Square Box
3 – Underline
4 – Strikethrough
Group Elements:
0 – aggregate
1 – composite line
2 – composite shape
3 – composite shape with holes
Embedded Data Type
gti_embeddedDataType
Embedded Data Type
Value can be 1 (tabular data). Other embedded data types may be supported in the future.
Embedded Data
gti_embeddedData
Embedded Tabular data (attribute/value pairs).
String value of any size.
Linkage
gti_key1
gti_key2
A one or two key linkage used to associate a graphic element with a tabular record. The keys are unsigned 32 bit integer values.
0 to max unsigned 32 bit integer.
Style Definition Id gti_style_def_id This attribute can be used to read or set the Style Definition Id. If the styleNameMap_byCat or styleNameMap_global Filter Creation modes are used, you should not set the gti_style_def_id since it will be set automatically.
0 means it is not used.
The following format attributes can be used with specific elements:
Property
FME Property Name
Description
Value Range
gti_shape32, gti_ellipse32, gti_circle32,
gti_fill
Determines if a shape, circle, or ellipse is to be filled or left empty.
0 – not filled, 1 – filled
gti_arc32, gti_arc64, gti_ellipse32, gti_ellipse64
gti_primary_axis
The Primary Axis size for an arc or ellipse element.
Unsigned long integer.
gti_secondary_axis
gti_start_angle
The start angle for an arc.
Angle in degrees.
gti_sweep_angle
The sweep angle for an arc.
Angle in degrees.
gti_arc32, gti_arc64, gti_ellipse32, gti_ellipse64,
gti_text32
gti_rotation
The rotation angle for various elements.
Angle in degrees.
gti_text32
gti_text_string
The text string
String value.
gti_text32
gti_text_heightMult
The text height multiplier.
Unsigned Long.
gti_text32
gti_text_font
The ID of the font to use for the text element.
0 to 255.
gti_text32
gti_text_justification
The text justification value to use with the text element.
0 – default (bottom/left)
100 – bottom/left
101 – center/left
102 – top/left
103 – bottom/center
104 – center/center
105 – top/center
106 – bottom/right
107 – center/right
108 – top/right
gti_text32
gti_text_multiline_dir
For text with multiple lines, the direction of the lines can be change from top to bottom to bottom to top. The default is top to bottom.
-1 – bottom to top
1 – top to bottom
gti_text32
gti_text_multiline_
spacing
The spacing of the lines default to 1.4 times the individual line height. This factor can be changed with this attribute.
Floating point value.
gti_fill_colorId
The color ID of the shape’s fill. If not defined, this color will be the element color.
0 to 255.
