Reader Directives
The suffixes listed are prefixed by the current <ReaderKeyword> in a mapping file. By default, the <ReaderKeyword> for the FME Server Stream (Attribute) reader is FMESERVERSTREAM_ATTRIBUTE.
DATASET
The DATASET directive for FME Server Stream (Attribute) reader is not used.
FME_SERVER_HOST
This specifies the machine running an FME Server instance to read as a host name.
The FME Server must have proper permissions and be set up correctly to accept connections from a remote machine.
Required/Optional
Required
Mapping File Syntax
FME_SERVER_HOST myfmeserver
FME_SERVER_PORT
When connecting remotely, this specifies the TCP/IP port through which to connect to the FME Server.
The default port is 7071.
Required/Optional
Optional
Mapping File Syntax
FME_SERVER _PASSWORD
This directive contains the password of the user accessing the FME Server.
Required/Optional
Required
Mapping File Syntax
FME_SERVER_PASSWORD password
FME_SERVER _USERNAME
This directive contains the name of user who will access the FME Server. The named user must exist with appropriate permissions.
Required/Optional
Required
Mapping File Syntax
FME_SERVER_USERNAME admin
REPOSITORY_NAME
This directive is the name of FME Server repository containing the target workspace.
Required/Optional
Required
Mapping File Syntax
REPOSITORY_NAME repository
WORKSPACE_NAME
This directive is the name of the target workspace which contains an FME Server Stream writer.
Required/Optional
Required
Mapping File Syntax
WORKSPACE_NAME workspace
DEF
This specification is used to define the files read.
Required/Optional
Optional
Mapping File Syntax
The syntax of the DEF directive is:
<ReaderKeyword>_DEF <baseName>  [<attrName> <attrType>]+
Note: This directive is not used when the dataset is a file.
Example
The example below defines a roads feature type during a translation:
<ReaderKeyword>_DEFs roads
