Feature Types
track_points
Geometry type: fme_point
Feature Attribute | Description |
ele | Elevation in meters. |
fix | Type of GPS fix. Possible values are none, 2d, 3d, and dgps. |
time |
Creation date/time, in UTC Format: YYYYMMDDHHMMSS |
course | Course of travel, in degrees |
speed | Speed of travel, in meters per second |
track_fid |
ID of the track feature to which the point belongs. Since DeLorme GPS Track Logs files only support a single track, this value is always 0. |
track_seg_id |
ID of the track segment to which the point belongs. Since DeLorme GPS Track Logs files only support a single track segment, this value is always 0. |
track_seg_point_id |
ID of the point in the track. |
tracks
Geometry type: fme_aggregate of lines
There are no attributes specific to tracks. The reader exposes tracks as a convenience only.
Since the DeLorme GPS Track Logs format only supports a single track and track segment, only a single feature of type fme_aggregate is returned, consisting of a single fme_line.
