IBM DB2 Non-Spatial (JDBC) Writer Parameters
Database Connections |
Connections store authentication information. For general information about sharing database connections, please see Using Database Connections. Note that different subsets of Database Connection parameters are made available in different contexts. Connection
Select an existing connection, or Add Database Connection to define a new connection. The new connection can be made visible only to the current user, or can be shared among multiple users. |
Connection Parameters
The host name of the IBM DB2 Database.
The connection port for the IBM DB2 Database.
The name of the database to connect to.
Enter the username and password to access the database, user account, or wherever authentication is required.
This parameter determines the number of features that FME will place in each transaction before a transaction is committed to the database.
The default value is 1000.
The time, in seconds, after which to terminate a query to the database if it has not yet returned a result.
If set to 0, there is no timeout. The default is 30.
Note: If this value is not set high enough, then the query will return the error Provider Error - Timeout Expired.
