AutoCAD Map 3D Object Data Quick Facts
About Quick Facts Tables
Format Type Identifier
AUTOCAD_OD
Reader/Writer
Both
Licensing Level
Professional and above
Dependencies
None
Dataset Type
File
Feature Type
Object Data Table name or Entity Layer name
Typical File Extensions
.dwg, .dxf
Automated Translation Support
Yes
User-Defined Attributes
Yes
Coordinate System Support
Yes
See Coordinate System Information.
Generic Color Support
Yes
Spatial Index
Never
Schema Required
Yes
Transaction Support
No
Geometry Type Attribute
autocad_entity
Encoding Support
Yes (object data attributes only)
AUTOCAD_OD Geometry Support
Geometry
Supported?
aggregate
no
circles
yes
circular arc
yes
donut polygon
yes
elliptical arc
yes
ellipses
yes
line
yes
none
no
point
yes
polygon
yes
raster
no
solid
no
surface
no
text
yes
z values
yes
