Extended Data
KML 2.2 provides the option to store attribute data in individual placemarks using either <Data> or <SchemaData> elements. For background, please read: http://code.google.com/apis/kml/documentation/extendeddata.html.
The key distinction between Data, and SchemaData is that SchemaData elements are associated with formal schema definitions in <Schema> elements.
The following element attributes are used by the KML reader and writer to read/write KML 2.2 extended data.
The KML reader and writer use a set of kml_data and kml_schema_data structured list attributes to read/write extended data.
KML Element Attribute
KML Element
kml_data{}.name
name attribute of <Data>
kml_data{}.value
<Data><value>
kml_data{}.display_name
<Data><displayName>
Optional.
Note: xml entities will be encoded on writing.
kml_data{}.display_name_raw_text
<Data><displayName>
Optional.
Note: Display_name values will written as raw text, i.e., xml entities will not be encoded. CDATA blocks should be added as necessary.
kml_schema_url
schemaUrl attribute of <SchemaData>
kml_schema_data{}.name
name attribute of <SimpleData>
kml_schema_data{}.value
Value of <SimpleData>
