Request and Install the License
Perform the following steps on the computer that acts as the license server:
- Click Start > Programs > FlexNet for Safe Software > View hostid.txt to open the hostid.txt file.
- Complete the online license request form:
- A trial activation code (for example, EDHAKQ5W) or
- A product serial number (for example, BEGP-F7MG-21YL).
- Hostname is the name of the computer hosting the floating license.
- Host ID is the MAC address (or "Ethernet address") of the host computer (lowercase, with no colons).
- You will receive an email with instructions for installing the license:
- Save the safe.lic file to the FlexServer directory. For example:
C:\Program Files\FlexServer\ - Restart the FME License Server:
If you are installing FlexNet on Windows Vista, Windows 7, or Windows 8 and User Account Control (UAC) is enabled, right-click Start-Restart FME License Server and run this function using administrator privileges. If UAC is not enabled, you do not have to perform this step.
http://www.safe.com/activation/floating/
You will need either:
If you don't have a trial activation code or product serial number, please e-mail your hostid.txt file to codes@safe.com.
If you are requesting a combined license and are entering multiple serial numbers, separate them with commas.
If you do not have hostid.txt and are entering host information manually:
Your hostid.txt may contain multiple Host IDs; however, you can enter only one in the online request form.
Start Menu > Programs > FlexNet for Safe Software> Start - Restart FME License Server
What's Next?
