You are here: Workspace BasicsCreating WorkspacesAbout TemplatesCreating Workspaces from Templates
The Create Workspace dialog (File > New) contains a list of available templates, either stored locally or downloadable from FME Hub:
  1. This area lists template types and categories.
  2. This area displays the templates that are stored in the selected category on the left.
  3. The tabs contain information associated with the template. See Workspace Properties for a description.
  4. Filter templates by keyword.
My Templates
When you create templates from existing workspaces, the template categories are added to this list. Click a category to see the workspaces
Installed Templates
Some templates are included with each FME Desktop installation. These will be shown here, along with any templates that you download and install from FME Hub for use with both FME Desktop and FME Server. Downloadable templates are updated frequently.
FME Hub
These templates are downloadable from FME Hub. FME Hub contains templates and custom transformers that are described as part of solutions on FME Knowledge Center.safe.com, as well as workspace elements created by third parties.
Downloading a Template
  1. To download a template, select it and click Choose, or double-click the template name.
  2. The Workbench log window shows the status of the download. The log window will look something like this:
Requesting catalog details for selected template...
Retrieved catalog details.
Connecting to FME Hub...
Successfully connected.
Downloading '<template_name>.fmwt.fmwt'...Successfully downloaded file.
Successfully downloaded '<template_name>.fmwt' from FME Server to '<default_location>\FME\FME Hub\Templates\LAS_PDF_3D.fmwt'.
Disconnecting...
Successfully disconnected.
Note: If you have an open workspace, you will be prompted to save and close the workspace.
  1. When the template opens in Workbench, it will already contain input data and transformers (if applicable), along with explanatory annotations.
  2. Click File > Save to save the template as a workspace on your computer. FME will create a folder on your local drive that contains both the workspace and any associated input data. The default location on Windows is \Documents\My FME Workspaces.
