You are here: Working with FME DesktopFME Administration TasksFME Files: Names and Locations
FME Filenames and Locations
Dataset Locations
Click on readers and writers in the Navigator and select Open Containing Folder (Ctrl + O).
File Extensions
FME has many associated file extensions. The default locations are listed here but can also change depending on where you installed FME.
Filename/File Extension
Type/Description
Default Location
coordsys.db
Contains the names and descriptions of all predefined coordinate systems.
FME installation folder
.fds
Custom Formats
My Documents\FME\Formats
.fme
FME mapping file (FME Quick Translator)
User-defined
.fmf FME metafile - Used to configure format definitions. FME installation folder, metafile subfolder
.fmelic FME license file User-defined
.fmv
FME Viewspace - Used by the FME Data Inspector to load a predefined view.
User-defined
.fmw
FME Workbench workspace
My Documents\My FME Workspaces
.fmwt
FME Workbench template - Used to package an FME workspace and source data.
This extension is also used for templates downloaded from FME Hub.
My Documents\FME\Templates
.fmx
Custom transformers
My Documents\FME\Transformers
.fmxlist
User-defined transformer list
My Documents\FME\TransformerCategories
.fmc
FME catalog file
Contains instructions to direct Workbench to download a specified resource from FME Knowledge Center.com. Since these files contain only instructions (XML), they are small in size.
.fps FME Feature Store (FFS) pointcloud sidecar file - Used to store FFS point cloud data.
.frs FME Feature Store (FFS) raster sidecar file - Used to store FFS raster data.
.fsi FME Feature Store (FFS) spatial index file - Used to store the spatial index for FFS datasets.
.gdc, .gsb, .las, .los, .mrt, .txt, .csv
Coordinate system and grid data files
Reproject
Reproject\GridData
MyCoordSysDefs.fme
custom coordinate system definitions
FME installation folder, Reproject subfolder
LocalCoordSysDefs.fme
This file is automatically loaded and made available to each FME session, to allow sites to add their own coordinate systems. It contains a series of COORDINATE_SYSTEM_DEF, DATUM_DEF, ELLIPSOID_DEF, and UNIT_DEF lines that define additional, site-specific coordinate systems.
You can edit these files to add your own definitions.
Reproject subfolder under the FME installation folder
Defining Custom Units
