You are here: Working with FME DesktopWorking with Coordinate SystemsDefining New Ellipsoids
Certain sites may require an ellipsoid that is not predefined in the FME. In such a case, a custom ellipsoid may be created. Ellipsoid definitions may occur in an FME mapping file, as well as in the LocalCoordSysDefs.fme.
The syntax of an ellipsoid definition is:
ELLIPSOID_DEF <ellipsoidName> \
   DESC_NM <descriptive name> \
   SOURCE <source> \
   E_RAD <equator radius> \
   P_RAD <polar radius>
Example Ellipsoid Definition
This mapping file fragment defines a sample ellipsoid:
ELLIPSOID_DEF myEllipse \
   DESC_NM “Safe Sample Ellipse” \
   SOURCE “Safe Software Inc.” \
   E_RAD 6377340.128 \
   P_RAD 63356034.448
Ellipsoid Definition Parameters
Name
Range Description Optional
<ellipsoidName>
any string
The name of the ellipsoid being de­fined.
No
<descriptive name>
any string
A descriptive name for the ellipsoid.
Yes
<source>
any string
The individual or agency providing the ellipsoid parameters.
Yes
<equator radius>
floating point value
The radius of the ellipsoid in meters at the equator.
No
<polar radius>
The radius of the ellipsoid in meters in the polar direction.
No
