Using Web Connections
Many transformers, readers, and writers require you to connect and authenticate to a web service in order to use them. For example, when you use an HTTPCaller transformer, you may need to authenticate to a web service, such as Google Fusion Tables. Web connections provide a convenient and secure way to store and reuse these connection parameters. Each time you need to use the same connection in a workspace, you can use the connection, rather than re-entering the connection parameters. If the connection parameters change, you can edit them in one place, rather than in each workspace that uses the connection.
FME Desktop must be registered to use the web services to which you want to connect. Fortunately, many of the most common web services are already registered in FME. Using the Web Connections tools (Tools > FME Options > Web Connections), you can specify your connection parameters to these services, as well as edit them or remove them altogether. It is usually more convenient to add a web connection at the time you are using one in a workspace. However, you can also add a web connection in Web Connections, and use it later in a workspace.
To Use a Web Connection in a Workspace
You can use an existing web connection, or define a new one, in a Transformer Parameters, Add Reader, or Add Writer dialog.
In the Edit Web Connection dialog, specify the web service, a name for the connection, and the connection parameters. If the web service uses the OAuth standard, click Authenticate and validate your connection directly with the web service.
Note: The following characters are not allowed in connection names: ^ \ / : * ? " < > | & = ' + % #
The next time you need to use the newly-created connection in a workspace, it will be listed in the drop-down menu of the Web Connection field.
  • Change the connection parameters.
  • Change a web connection to one that exposes the connection parameters in the workspace.
  • Change a connection whose parameters are exposed in the workspace to a web connection.
See Also
