You are here: LicensingFloating LicensesInstalling a Three-Server Redundant Floating License Server on WindowsStart FME Registration
Perform this step for each computer that has FME installed.
For command prompt instructions, see Licensing FME Desktop from the Windows Command Prompt.
- Open the FME Licensing Assistant: Start > Programs > FME Desktop > Utilities > FME Licensing Assistant.
- Select Connect to a floating license server, and enter the name of the master node computer that is hosting the license.
- Click the Next button.
- If your configuration contains more than one type of FME license, select the license that you want to use.
- Click Finish to complete the connection.
