You are here: LicensingFloating LicensesInstalling a Floating License on WindowsDownload and Run the Installer
The FME installer contains the utility program required to get the license server up and running:
  • fme-flexnet-win-x86.msi (Windows 32-bit)
  • Or
  • fme-flexnet-win-x64.msi (Windows 64-bit)
You can download the installer from Safe Software’s site:
http://www.safe.com/support/support-resources/fme-downloads/
On the computer that acts as the license server, run (double-click) the installer to create a FlexServer directory.
The following table lists the shortcuts that are created in the Safe Software program group.
Shortcut
Description
Generate hostid.txt
Creates a text file that contains the hostname and Host ID information required when requesting a floating license from www.safe.com/activation/floating/.
Launch LMTOOLS
Launches LMTOOLS. Used for debugging or changing configuration.
License Administration Guide
Opens Flexera Software’s License Administration Guide.
Start - Restart FME License Server
Starts the license manager process.
View FME License Server Log
Opens the license manager log file. Used for debugging.
View hostid.txt
Reopens text file, if required by Safe Software.
View Readme
Opens the installation and configuration instructions.
What's Next?
