You are here: LicensingSingle-Fixed LicensesActivating a Single Fixed License
Activating a Single-Fixed License
If you have a serial number and an Internet connection, follow these steps to activate a fixed license from Safe Software.
If you already have a licensed installation, you will be prompted to update it.
If you change your system's hardware configuration after installation, your FME license may not work and you will need to request a new one.
  1. Open the FME Licensing Assistant
    • On Windows, click the Start menu > Programs > FME Desktop > Utilities > FME Licensing Assistant.
    • On Linux, log in as the same user who installed FME Desktop. Navigate to Application > FME Desktop > Utilities > FME Licensing Assistant.
  2. The FME Licensing Assistant opens.
  3. Select Activate a single-fixed license. Enter the Serial Number in the corresponding field, and click Activate.
  4. Click Finish.
  5. You will see a confirmation message when FME Desktop is successfully licensed.
Other Licensing Options
Three additional licensing options are available in this dialog.
