Tools > Browse Readers and Writers
The Reader and Writer Gallery lists all formats supported by FME.
It includes the following information:
Column | Definition | ||||||
Description | Full format name | ||||||
Short Name | Common abbreviation for the format | ||||||
Extensions | Lists file extension(s) associated with the format | ||||||
Type | Indicates whether the format is a file- or folder-based format | ||||||
Read/Write | Indicates whether the format is a reader, a writer, or both | ||||||
Coordinate System | Indicates whether a custom coordinate system is associated with the format | ||||||
Licensed | Some formats require that you obtain special licensing, or specific versions of FME. This column indicates whether your FME is licensed to read/write the format | ||||||
Search | Enter a keyword or a partial text string to filter results. | ||||||
Custom Formats |
The following icons identify Custom Formats in the Reader and Writer Gallery:
Close | Close the gallery. | ||||||
Details | Click on a format, then click Details to display the technical documentation for the format. |
