You are here: FME Workbench > Working with User Parameters > Adding a Parameter
Creating and Modifying User Parameters
There are different ways to create user parameters:
The method you choose determines the fields that show in the Add/Edit Parameter dialog. The configurable fields in the dialog are described following the table.
User Parameter Type Description Add/Edit Parameter Dialog
To add a new user parameter that has no existing properties
Right-click the User Parameters icon in the Navigator, and click Add Parameter.
This is a new parameter, so you will have to fill in all required fields.
Click OK to add the parameter to the workspace.
To create a user parameter from an existing workspace parameter
Right-click a Workspace Parameter in the Navigator, and click Create User Parameter.
Most fields are already filled in based on the parameter's existing information. You can edit the fields; however, changing the Type is not recommended.
To create a user parameter from an existing transformer parameter (Navigator)
Right-click a Transformer parameter in the Navigator, and click Create User Parameter.
Click OK to add the parameter to the transformer.
Detailed example
To create a user parameter from an existing transformer parameter (Transformer Parameters dialog)
Click the menu beside a parameter in the parameters dialog of a transformer and click User Parameter > Create User Parameter.
You can edit all the fields.
Add/Edit Parameter Dialog Fields
All user parameters will be listed in the User Parameters section of the Navigator.
