Setting Feature Type Fanout
See About Fanout for more information
on dataset fanout.
See Setting Dataset
Fanout for more information on setting dataset fanout.
The fanout settings in the Feature Type Properties dialog allow you
to use that specific feature type as a template for dynamically created
feature types.
Feature type fanout means that many feature types will be created from
one template feature type. How this actually appears as output depends
entirely on the format. For
example:
- AutoCAD
is a file-based format, so each feature type created will be a different
layer in the AutoCAD file.
- Shape is a folder-based format, so each feature
type created is a new Shapefile.
- Oracle is a database format, so each new feature
type is created as a new table in the database.
Steps
- Click the Feature Type properties button
on an destination feature type.
- Check Fanout By Attribute.
- Choose the Fanout Attribute from the drop-down
menu. A new feature type will be created for each unique value of the
fanout attribute, and all features with that value will be written to
the resulting new feature type.
- Click OK
to apply the properties to the feature type from which you initiated the
properties dialog. Click Apply to... if you want to apply
these properties to all feature types in your output dataset.
You can combine Feature Type and Dataset Fanouts.
For example, if you are working with a folder-based format and you
perform a feature type fanout on attribute A and a dataset fanout on attribute
B, then you'll end up with multiple folders of files, with the filenames
dependent on the values of attribute A.
