This parameter identifies the pathname of a connection file to be used to connect to an Enterprise Geodatabase. A connection file provides the necessary information to connect to the SDE server, such as the server name or the username. The connection file must be a *.sde file and have the proper format for a connection file as defined by Esri. Connection files can be created in ArcCatalog.
Check this option to override the User and Password from the connection file. Overriding credentials is required for Connection Files that do not have saved credentials.
This parameter is ignored if the Connection File is using OS Authentication.
Enter the username and password to access the database, user account, or wherever authentication is required.
After you have completely specified the database connection, click the Browse button to select tables for import. A connection window appears while the system compiles a table from the database.
Once the table list appears, you can select one or more tables, and then click OK to dismiss the window. The table name(s) will appear in the table list field in the Parameter box.
Enter any SQL where clause that constrains the attributes of the layers selected in the list (for example, NUMLANES=2).
This parameter exposes Format Attributes in Workbench when you create a workspace:
Using the minimum and maximum x and y parameters, define a bounding box that will be used to filter the input features. Only features that interact with the bounding box are returned.
If all four coordinates of the search envelope are specified as 0, the search envelope will be disabled.
Select this option to remove any portions of exported features outside the area of interest.
