You are here: FME Workbench > Feature Types and Attributes > Regular Expressions > Escapes
Escapes
Escapes (AREs only), which begin with a \ followed by an alphanumeric character, come in several varieties: character entry, class shorthands, constraint escapes, and back references. A \ followed by an alphanumeric character but not constituting a valid escape is illegal in AREs. In EREs, there are no escapes: outside a bracket expression, a \ followed by an alphanumeric character merely stands for that character as an ordinary character, and inside a bracket expression, \ is an ordinary character. (The latter is the one actual incompatibility between EREs and AREs.)
Character-entry escapes (AREs only) exist to make it easier to specify non-printing and otherwise inconvenient characters in REs:
\a   alert (bell) character, as in C
\b   backspace, as in C
\B   synonym for \ to help reduce backslash doubling in some applications where there are multiple levels of backslash processing
\cX   (where X is any character) the character whose low- order 5 bits are the same as those of X, and whose other bits are all zero
\e   he character whose collating-sequence name is `ESC', or failing that, the character with octal value 033
\f   formfeed, as in C
\n   newline, as in C
\r   carriage return, as in C
\t   horizontal tab, as in C
\uwxyz   (where wxyz is exactly four hexadecimal digits) the Unicode character U+wxyz in the local byte ordering
\Ustuvwxyz   where stuvwxyz is exactly eight hexadecimal digits) reserved for a somewhat-hypothetical Unicode exten­sion to 32 bits
\v   vertical tab, as in C are all available.
\xhhh   (where hhh is any sequence of hexadecimal digits) the character whose hexadecimal value is 0xhhh (a single character no matter how many hexadecimal digits are used).
\0    the character whose value is 0
\xy   (where xy is exactly two octal digits, and is not a back reference (see below)) the character whose octal value is 0xy
\xyz   (where xyz is exactly three octal digits, and is not a back reference (see below)) the character whose octal value is 0xyz
Hexadecimal digits are `0'-`9', `a'-`f', and `A'-`F'. Octal digits are `0'-`7'.
The character-entry escapes are always taken as ordinary characters. For example, \135 is ] in ASCII, but \135 does not terminate a bracket expression. Beware, however, that some applications (e.g., C compilers) interpret such sequences themselves before the regular-expression package gets to see them, which may require doubling (quadrupling, etc.) the `\'.
Class-shorthand escapes (AREs only) provide shorthands for certain commonly-used character classes:
\d   [[:digit:]]
\s   [[:space:]]
\w   [[:alnum:]_] (note underscore)
\D   [^[:digit:]]
\S   [^[:space:]]
\W   [^[:alnum:]_] (note underscore)
Within bracket expressions, `\d', `\s', and `\w' lose their outer brackets, and `\D', `\S', and `\W' are illegal. (So, for example, [a-c\d] is equivalent to [a- | c[:digit:]]. Also, [a-c\D], which is equivalent to [a- | c^[:digit:]], is illegal.)
A constraint escape (AREs only) is a constraint, matching the empty string if specific conditions are met, written as an escape:
\A   matches only at the beginning of the string (see MATCHING, below, for how this differs from `^')
\m   matches only at the beginning of a word
\M   matches only at the end of a word
\y   matches only at the beginning or end of a word
\Y   matches only at a point that is not the beginning or end of a word
\Z   matches only at the end of the string (see MATCH­ING, below, for how this differs from `$')
\m   (where m is a nonzero digit) a back reference, see below
\mnn   (where m is a nonzero digit, and nn is some more digits, and the decimal value mnn is not greater than the number of closing capturing parentheses seen so far) a back reference, see below
A word is defined as in the specification of [[:<:]] and [[:>:]] above. Constraint escapes are illegal within bracket expressions.
A back reference (AREs only) matches the same string matched by the parenthesized subexpression specified by the number, so that (e.g.) ([bc])\1 matches bb or cc but not `bc'. The subexpression must entirely precede the back reference in the RE. Subexpressions are numbered in the order of their leading parentheses. Non-capturing parentheses do not define subexpressions.
There is an inherent historical ambiguity between octal character-entry escapes and back references, which is resolved by heuristics, as hinted at above. A leading zero always indicates an octal escape. A single non-zero digit, not followed by another digit, is always taken as a back reference. A multi-digit sequence not starting with a zero is taken as a back reference if it comes after a suitable subexpression (i.e. the number is in the legal range for a back reference), and otherwise is taken as octal.
