The Catalog service allows us to create web links that users can use to download workspaces, templates, custom formats and custom transformers from FME Server using FME Workbench via .fmc files.
The catalog service allows registered workspaces to be browseable via the web. The purpose of this service is to make it easier to download and load various FME resources into FME Workbench from anywhere on the web. One prominent example is automatic download and loading of FME examples and demos from fmepedia.com.
There are three usages for the catalog service. They are described below.
Request URL
http://<host>[:port]/fmecatalog/<repository>/
<workspace>{.format}
Service-Specific Request Parameters
The following table describes the service-specific options.
Name |
Value |
Description |
opt_format |
xml | json |
The format to respond in |
| opt_metadata | wps | If this option is set, the Catalog service will return WPS parameter mappings for the specified workspace. |
Response Elements
A service response may contain the elements shown in the following table.
Element |
Child Elements |
Value |
Description |
statusInfo |
message |
message string |
service failure message |
Request URL
http://<host>[:port]/fmecatalog/catalog{.format}?
{name[=value]&}
Note: Only repositories to which the requestor has "Read" permission are returned by the Catalog Service. For more information about Web Services authentication, see Authentication and Authorization.
Name |
Value |
Description |
opt_format |
xml | json |
The format to return the response in |
opt_repfilter |
string |
Filter by repository. Use '*' at start/end to signal suffix/prefix. |
| opt_itemtype | WORKSPACE | CUSTOMFORMAT | CUSTOMTRANSFORM | TEMPLATE | Specifies the type of repository items being returned from the catalog. All item types will be returned by default. |
A successful service response may contain the elements shown in the following table.
Element |
Child Elements |
Value |
Description |
catalog |
category |
category elements |
list of workspaces grouped by repository |
category |
name |
string |
name of the repository |
description |
string |
description of the repository |
workspace |
item elements |
information about the workspace |
workspace |
name |
string |
name of the item |
description |
string |
description of the item |
url |
url string |
url of the item |
Note: The response may be cached, so it may be necessary to reset the cache for accurate results.
It is important to reset the cache for the most up-to-date response.
Request URL
https://<host>[:port]/fmecatalog/resetcache
