You are here: FME Server Administrator's Guide > Common Configurations > Migrating an FME Server Configuration
You can migrate the configuration of an FME Server instance to another instance.
To migrate the configuration of an FME Server 2013 instance, create a workspace in FME Workbench using the FME Server Configuration reader and writer. The FME Server Configuration format supports migrating repositories, services, notifications, security and scheduling.
Note:  To use the FME Server Configuration format, your user account must be assigned to the fmesuperuser role. For information about configuring user roles in the Web User Interface, see Users Table. For information about configuring fmesuperuser priveleges through Active Directory, see Enabling fmesuperuser Privileges in Active Directory.
Note:  The FME Server Configuration format does not migrate or backup the contents of the FME Server configuration files: fmeEngineConfig.txt, fmeServerConfig.txt, processMonitorConfig.txt
Note:  The FME Server Configuration format is not compatible with FME Server version 2012 or earlier.
In the reader, specify the FME Server instance whose configuration you are migrating. In the writer, specify the FME Server instance to which you are migrating the configuration.
For more information about how to use the FME Server Configuration format, see the FME Readers and Writers Help, included with your FME Desktop installation.
