Safe Software requires three pieces of information to generate a floating or node-locked license:
The following sections provide details about these requirements.
To obtain the hostname, type the hostname command. For example:
% hostname
worf
In this example, the host name is worf.
To determine the host ID, use the lmutil lmhostid command within the FlexServer directory. The output is an eight-character alphanumeric string (or a 12-character alphanumeric string on Linux/UNIX). For example:
% ./lmutil lmhostid
lmutil - Copyright (c) 1989-2009
The FLEXlm host ID of this computer is "807abc12"
In this example, the host ID is 807abc12.
To determine the serial number, look at your welcome letter or your invoice.
Send an email message to codes@safe.com, and include the host ID, the host name, and the FME serial number. Safe Software will email you a file called safe.lic that contains the key code file for the license code server.
Copy the safe.lic file into the FlexServer directory on your license server computer.
Note: The filename must remain in lower case text. We recommend that you do not change the filename. If you want to change the file contents (for example, change a port number), refer to the FLEXlm User’s Guide, available on your FME installation disk.
If you are using the built-in FME Server License Server, the License Server directory is:
<FMEServerDir>/FMEServer/Utilities/flexserver
