You can download the installer from Safe Software’s site:
http://www.safe.com/fme/fme-technology/fme-server/download/
On the computer that acts as the license server:
The following table lists the shortcuts that are created in the Safe Software program group.
Shortcut |
Description |
Generate hostid.txt |
Creates text file to send to codes@safe.com. |
Launch LMTOOLS |
Launches LMTOOLS. Used for debugging or changing configuration. |
License Administration Guide |
Opens Flexera Software’s License Administration Guide. |
Start - Restart FME License Server |
Starts the license manager process. |
View FME License Server Log |
Opens the license manager log file. Used for debugging. |
View hostid.txt |
Reopens text file to send to codes@safe.com. |
View Readme |
Opens the installation and configuration instructions. |
Note: Current versions of lmgrd license manager and lmutil end user utilities are also available from the Downloads area of www.flexera.com.
Read and understand the following steps before attempting to use FLEXlm licensing on Solaris™ or Linux on x86 and x64.
If you purchased an FME floating or single-fixed license for UNIX, copy the solaris2\FlexServer or Linux\FlexServer directories from the FME installation disk, or go to Safe Software’s FTP site and save one of the following files:
This directory contains the lmutil and lmgrd files required to set up a FLEXlm server on UNIX, and it contains the FLEXlm license server software. Install this software on your license server computer, which is the computer that manages the licenses.
Create a directory for the FLEXlm license server, and extract the contents of flexServer11_8-solaris-sparc64.tar.gz or flexServer11_8-linux-x64.tar.gz into that directory. For example:
% mkdir /opt/FlexServer
% cd /opt/FlexServer
% gunzip < ~/flexserver11_8-solaris-sparc64.tar.gz | tar xf -
This directory is referred to as the FlexServer directory for the remainder of these instructions.
Note: To start the Flex Server, verify that the /usr/tmp directory exists. If it does not exist, create it by entering:
% mkdir /usr/tmp
To start the license server, enter:
% <FlexServerDir>/lmgrd -c <FLEXServerDir>/safe.lic
This action runs the server in the foreground, logging activity to the terminal. To store the log to a file instead, use the -l option:
% ./lmgrd -c ./safe.lic -l safe.log
When a log file is used, lmgrd detaches as a background process, so there is no need to explicitly put the application in the background . However, you must start the server each time the license server host is rebooted. The system administrator can make sure the preceding command is run at system start-up time.
